Holes in toposolids
Hi everyone,
I’m working with Rhino.Inside.Revit (Revit 24, Rhino 7) on toposolids that have openings. Everything has been working fine until I ran into this specific case I’m attaching.
I can’t seem to get the opening to work. The problem is with the curve that should create the opening, and I’m a bit stuck. I’ve already checked that the curve is:
  • Planar
  • Closed
  • Without segments that are too small
  • Not self-intersecting
It still doesn’t work, and I honestly don’t know what else could be causing the problem.
I’m attaching the file and a screenshot showing the setup. Please note that in the file, I’ve left the wires disconnected to avoid any crashes or strange behavior when opening it, but the idea is that they should be connected as shown in the screenshot.
Would anyone be able to help me figure out what’s going wrong? I’d really appreciate any suggestions.
toposolid holes.gh (80.7 KB)
Thank you for reading, and have a great day!
@Fabio_Franchetti I don’t see any issue
