History of Networksrf on Rhiono 6
Shouldn’t I use the edges of extruded surfaces in Rhino6 NetworkSrf?
In the following situations…
I want to adjust a new surface with side frame curves after NetwarkSrf…
therefore I had used NetworkSrf on Rhino 4.
but, the history of NetworkSrf on Rhino 6 sometimes don’t works same situation.
History works fine when I use NetworkSrf after trimming the extruded surface.
It is a pain in the neck.
best.
Maybe run the ConvertExtrusion command prior to running NetworkSrf. It looks like the extrusion is the problem, so convert it to a “normal” surface first with ConvertExtrusion.
Thanks Great Answer!
I was looking for help for the ConvertExtrusion and found UseExtrusions.
I finally understand why I was also failing in Grasshopper’s NetworkSrf.
best!!!
Hello - I see this, thanks.
https://mcneel.myjetbrains.com/youtrack/issue/RH-55247
RH-55247 is fixed in the latest WIP
