Hello all,
I’m hoping you can help me solve this puzzle. My dimensions keep moving off of my measured objects.
I have a block instance and a linear dimension. They are grouped.
I make a mirror image of the group. If I move the parent group, then the child group mirrors it.
If I select both the parent and the child groups and move them together, the parent moves as expected. The child block moves in the same direction as the move command, but the child dimension is still mirroring.
Why doesn’t the history relationship on the dimensions break when they are selected and moved? I have tried this both with the objects grouped and ungrouped and get the same results.
On a side note, is there a way to keep the text on the dimensions from flipping when it is mirrored?
