History and Distribute
How does the Distribute command interact with Rhino History?
Here I have 1 gem:
Here I make a linear array of 10 gems with 0.20 mm between them.
Let’s say I’d rather have a space of 0.50 mm between them so I use Distribute (Mode=Gap Spacing=0.50) in the YAxis. Here is the result I get.
Clearly, the gems at the top of the line have a 0.50 mm gap but the ones at the bottom do not. What’s going on here?
No, Distribute is Not “History enabled”
If you want to know, start a command and press F1 to open the Help file article for it.
Commands that are History enabled have a decoration at the top of the Help article.
Here’s what Loft looks like that is history aware:
Thanks John.
I understand that it’s not history enabled, but I was hoping that Distribute would break history on the child objects in the same way that Move does.
