Anyone know how to get either a Histogram, Bar Chart (or just the data needed to chart) from the output of the Create Set component?
So basicaly the frequencies of the items in each set created from the original data?
CreateSetHistogram.gh (5.0 KB)
akilli
(Ethan Gross)
#2
Hi Martyn. You can use MemberIndex as below but I don’t know if the bar graph in Gh gives you the results you’re looking for.
CreateSetHistogram2.gh (8.8 KB)
Thanks Ethan… Literally just discovered the Bar Chart component but the member index is also just what I was looking for!
Thanks!
