Using Python script.
Do I have to call sc.doc.Objects.UnselectAll() when highlighting a subobject within a polycurve? The following code will not highlight the first subobject in the polycurve unless I call UnselectAll. I also tried calling Rhino.Input.Custom.GetObject.EnableHighlight(False) hoping the HighlightSubObject call would work.
I noticed if I use rs.GetObject() the subobject is highlighted, so I stepped through rhinoscript (selection.py) and noticed it calls scriptcontext.doc.Objects.UnselectAll(). Must his method be called or is there some property or method in the GetObject class that can be set so that I don’t have to call UnselectAll? Setting a property is a bit more cleaner in my opinion rather than going outside the class.
def HighlightFirstSubCurve():
filter = Rhino.DocObjects.ObjectType.Curve
go = Rhino.Input.Custom.GetObject()
go.SetCommandPrompt('Get polycurve.')
go.GeometryFilter = filter
go.EnablePreSelect(False, True)
go.DeselectAllBeforePostSelect = False
#go.EnableHighlight(False)
go.Get()
rc = go.CommandResult()
if rc != Rhino.Commands.Result.Success:
return
obj = go.Object(0).ObjectId
print str(obj)
#sc.doc.Objects.UnselectAll()
rhObj = sc.doc.Objects.Find(obj)
if not isinstance(rhObj.Geometry, Rhino.Geometry.PolyCurve):
print 'User did not select a polycurve.'
ci = Rhino.Geometry.ComponentIndex(Rhino.Geometry.ComponentIndexType.PolycurveSegment, 0)
rhObj.HighlightSubObject(ci, True)
sc.doc.Views.Redraw()
if __name__ == '__main__':
