Highlight selection
You have changed the style selection.
I need to revert to the Rhino 7 style selections. I need to display all isocurves when they are selected.
What’s the command/setting?
Thanks.
I’ve found it!
Hello- this will be turned off again shortly - you can change the setting in Options > Advanced > type “Silhouette”
It’s really goddawful for curves… So if you are going to have this as an option, please have a separate independent options for curves and surfaces…
Yep, it will be turned off for V8, and worked on…
