Hello Rhino Forum members,
I got e very specific question. I would like to achieve the following combination: turn off the isocurve-display on selecting objects while the selected faces are highlighted - which I partly already accomplished, due to a hint in this forum. But this works only for polysurface selection. As soon as I limited the selection to single faces, only the edges are highlighted but not the faces:
As soon as the selection is limited to faces the result looks like this:
Maybe there is a command option similar to the one I found here to toggle the isocurve display for selection ("-_Properties _Object _ShowIsocurves _No _EnterEnd" and “-_Properties _Object _ShowIsocurves _Yes _EnterEnd”).
Thanks a lot in advance!
Thomas
