High res captures incomplete
#1
Different from the previous issue with passes, it’s getting irritatingly regular now(on two machines with and without a Caustic board)that the final capture to file or clipboard will have 1/4 or 1/6th or so blank grey.
#2
I just got an R2500 yesterday(the dual Xeon workstation to ‘really make it work’ is still coming) and same thing. Have to restart Rhino to temporarily fix it. The captures aren’t that huge, 3000X3000 and 3000X1500.
(Andrew le Bihan) #3
Are you using the new version of Neon I sent you a while back?
#4
Yep.
#5
Same problem at similar resolutions a couple of weeks ago.
#6
Did you try the script I sent you?
And did you try leaving the computer fully alone while it worked?
And could you post a sample image or a sample file?
(Andrew le Bihan) #7
Jim
I’ll put together some debugging stuff to figure this out on Monday. Sorry I can’t get there any faster.
Andy
#8
If I just open up Rhino and do nothing else but let the “preview” render out, and capture, that usually works. Otherwise…
