High Point Count in Resulting Objects (Flow, etc.)
Is there a way to maintain the overall point count or span/isocurve count when using commands like “Flow” and others? The resulting objects have always a way higher number of points and spans.
Thank you
PreserveStructure=yes
Wow. Why is that not a default setting? Thank you!
well, the tool tries to give the optimal result for your target curve geometry.
so if your flow object has minimal/low number of spans, it can’t match the target.
in your case the geometry you are flowing already has lots of spans, so you won’t really see much detail missing. but it always depends on how much precision you need.
for manufacture/construction that can be below what your eye can tell in the viewport.
@dk2079 thank you for your clarification!
