High accuracy of brep from Tekla
Hello!
I have a question: Is it possible to display 3D solids in high resolution in such a way that the radius of the Tekla profile is shown as a true radius, rather than as straight line segments approximating the radius?
You can only display it as accurate as it is in Tekla. So a true radius is not possible since Tekla segments everything in order for large models to run smoothly.
You can however do some GH magic and get a true arc in GH with some scripting.
Hi Oskar
Thank you for the response. It’s a pity that such a magical script is out of my reach. I don’t know anything about programming :frowning:
No “programming” needed, use the Grasshopper components and you can make it work.
