V5
rather than have to find all my dims layers and turn them off, I wish to HideDims in one simple go.
HideCurves Likewise just to see the solids I need to do the same to curves used to make the solids.
Ideally HideDimsCurves would be a third great one., all done in one button.
Obviously with right click show option on the button for all these three.
go from a working view to clean view in one click.
This would be a real time saver.
I had a screenshare and no time to tidy up as such, very unpro !
Takes ages either selecting and running hide, or finding layers and turning off, then running turn off layer for selected trouble with that is I might have solids and curves on same layer !
It sounds as though you’ve been pretty organised and got things sorted neatly into layers. If that’s so, wouldn’t layer state manager allow you to achieve what you want?
Just set the layers with those showing the dims and curves ‘off’, then save that as a layer state. Save another with the layers set for modelling or whatever you want to do. Rename the states to something meaningful.
I have dims in many layers, I always (or try to) have a layer named DIMS for ‘name of object’.
I am forever adding layers and DIMS layers, so firstly having to find all my DIMS layers is going to take ages, then the LSM will be out of date as soon as I create another DIMS layer.
