HiddenLineDrawing segment visibility is wrong?!
Hi.
I am trying to use HiddenLineDrawing class to make a custom component. My component gets a block as an input and gives 4 Make2Ds as outputs from different views of that block. My problem is that when I set Segment Visibility to “visible”, it doesn’t seem to work correct and the result is wrong.
Does anyone know what the problem might be? Thanks.
