HiddenLineDrawing - how to get ObjectID of the HiddenLineDrawingSegment
when I use HiddenLineDrawing to create 2D drawing of multiple objects, is there a way to find out which line is from which object? - preferably to get object guid
I use python and rhinocommon
thanks in advance
Aleksandar
Hi @AleksandarSM,
When adding objects to a HiddenLineDrawingParameters object, do so like this:
hld_params.AddGeometry(obj.Geometry, Transform.Identity, obj.Id);
where obj.Id is the id of the RhinoObject.
After computing the soluation, iterate through the HiddenLineDrawing.Segments collection to process each HiddenLineDrawingSegment object. A HiddenLineDrawingSegment should have a “parent curve”, or HiddenLineDrawingObjectCurve. This object will a source object, or HiddenLineDrawingObject. On this object you will find the id “tag” you added above.
– Dale
