@rajaa I am working along the below example to implement a custom version of HiddenLineDrawing.Compute
Relevant part of example code:
//add objects to hld_param
foreach (var obj_ref in _obj_refs)
var obj = obj_ref.Object();
_hld_params.AddGeometry(obj.Geometry, Transform.Identity, obj.Id);
I am not able to add blocks or any other custom objects (VisualArq objects) to the HDL parameters. AddGeometry()
returns null
when trying to do so. How would I go about to add those? I assume I have to get to their geometry or is there a faster way?
Please find a demo script and test file below.
import Rhino.Geometry as rhg
import scriptcontext as sc
def test_hidden_line():
viewport = sc.doc.Views.ActiveView.ActiveViewport
# Setup HLD parameters
parameters = rhg.HiddenLineDrawingParameters()
parameters.AbsoluteTolerance = sc.doc.ModelAbsoluteTolerance
parameters.IncludeHiddenCurves = False
parameters.IncludeTangentEdges = False
parameters.IncludeTangentSeams = False
parameters.SetViewport(viewport)
# Process all of the document objects
rh_obj_guids = rs.AllObjects(include_references=True)
not_added = []
added = []
for obj_guid in rh_obj_guids:
rh_obj = rs.coercerhinoobject(obj_guid)
res = parameters.AddGeometry(rh_obj.Geometry, rh_obj.Id)
if res:
added.append(obj_guid)
else:
not_added.append(obj_guid)
# DEBUG: Objects not added are selected <--------------- Blocks are ignored
rs.UnselectAllObjects()
rs.SelectObjects(not_added)
# Create the hidden line drawing geometry
hld = rhg.HiddenLineDrawing.Compute(parameters, True)
# Add hidden line drawing to doc
flatten = rhg.Transform.PlanarProjection(rhg.Plane.WorldXY)
page_box = hld.BoundingBox(True)
delta2D = rhg.Vector2d(0, 0)
delta2D = delta2D - rhg.Vector2d(page_box.Min.X, page_box.Min.Y)
delta3D = rhg.Transform.Translation(rhg.Vector3d(delta2D.X, delta2D.Y, 0.0))
flatten = delta3D * flatten
attributes = sc.doc.CreateDefaultAttributes()
crvs = []
for hld_curve in hld.Segments:
if (hld_curve is None
or hld_curve.ParentCurve is None
or hld_curve.ParentCurve.SilhouetteType == rhg.SilhouetteType.None):
continue
crv = hld_curve.CurveGeometry.DuplicateCurve()
if crv:
crv.Transform(flatten)
if hld_curve.SegmentVisibility == rhg.HiddenLineDrawingSegment.Visibility.Visible:
if hld_curve.ParentCurve.SilhouetteType == rhg.SilhouetteType.SectionCut:
sc.doc.Objects.AddCurve(crv, attributes)
else:
elif hld_curve.SegmentVisibility == rhg.HiddenLineDrawingSegment.Visibility.Hidden:
else:
sc.doc.Objects.AddCurve(crv, attributes);
test_hidden_line()
HiddenLineTest.3dm (5.4 MB)
Thanks for your help!
