Hidden Lines Make2D
Hello is there a way to make the hidden lines jagged again? the image of the right was a version created in 2019 and jagged was the default way of creating lines with the make2d command. Thank you.
Found out that in the document with the proper jagged lines the Make2D command works fine. This is somehow document dependent. Checked options but there are only the print options. which have no effect. Thank you
I don’t know why the Make2D command will not put the hidden lines into a new jagged line style. But I was able to set the layer properties to jagged/hidden.
