Hidden display mode causes Window/Crossing selection to miss objects
Hi @badileanu,
We’ve just fixed some related issues in VisualARQ 3.12 RC2. You can check the changes and download it from this post: VisualARQ 3 - Version 3.12 RC3 released
There may still be some objects that aren’t selected when doing a cross or window selection, but that’s not a bug, it’s an intentional feature. Hidden display mode is mainly used for working in plan or section views with cut planes. For example, if you’re working on the second floor and the slab hides objects from lower levels, it would be uncomfortable to have those invisible objects selected. We tried enabling selection for them, but it made working in plan view nearly impossible, especially when annotating or moving furniture.
In VisualARQ 3.12, we improved selection so objects that should be visible but are occluded because another object is drawn using the same pixels (like two coincident curves) will now both be selected.
Please test VisualARQ 3.12 and let me know if now it works better for you.
Enric
