Grasshopper geniuses, I beseech thee. Yeah, the surface morph is not exactly morphing, I have a funky shape and the surface is just making a rectangle that encompasses my shape. Also, I am trying to make like 25% of lower part have the pattern, I tried to mess with the domain but there is this disgusting bar on top to make a rectangle. Finally, I am trying to cover all green outsides and I tried set multiple surfaces on the surface node(after I exploded everything) but no good. Should i split my questions into multiple posts?
how do I get it in the morph in right shape?
how do I do a seamless fade of the pattern?
Is there a way I could morph to all surfaces or am I just going to feal with funky lines?
the error messages were
[1. Splitting returned no results]from surface split node
[1. Data conversion failed from Surface to Rectangle] from populate geometry and [1. Insufficient points for voronoi diagram. You need at least one].
I then tried putting a 42 into the points for populate geometry, error messages:
[1. Data conversion failed from Surface to Rectangle] [2. Data conversion failed from Number to Point] from populate geometry
[1. Insufficient points for voronoi diagram. You need at least one] [2. Data conversion failed from Surface to Rectangle] from vornoi
