Hi, I need help getting this texture
Hi, I’m pretty new with gh and I want to 3D print texture like that in the pictures attached… can someone please help me with that, thanks :pray:t3:
Because that is less like a texture and more like actual geometry you’re going to end up with very thin sections…these pieces will probably not even print they’ll be so thin. I would ignore the ‘stem’ in that detail and focus just on the balls at the end - so your texture has the appearance of being covered by a lot of balls / egg shapes. (So maybe some kind of sphere / circle packing to solve covering the surface)
Hi, thanks for the reply!
the layer needs to be around a 0.8-1mm.
i wants to 3D print it for a lampshade so that the light can be slightly seen through the layers(like the second picture)
