Some of the curves along the edges are overlapped which causes problems connecting them.
connect points_2020Nov25a.gh (44.1 KB)
Hi @HS_Kim and @Joseph_Oster , is it possible to create a surface and extrude those line we connected? can you please help me. please refer to image. thanks
You are running into all sorts of challenges ![]()
The grid you provided isn’t nicely aligned.
Generally it would be better to start with a surface, divide it and create a clean network of lines.
The beams can be done in many ways. I trimmed the lines and used two planes per beam, resulting in a straight but twisted beam for those that are at an angle. You might want a curved beam without twist.
The solution is dependent on a lot of decisions. Maybe you want as many beams as possible to be equal, or all possible nodes equal?
20_11_26_triangular_grid_beam_connector.gh (53.1 KB)
PS: a title should be short, for example “Problem with triangular grid and connectors”
Thank you very much @martinsiegrist for the solution you made. Yes you are right. Actually i want all my nodes to be equal as possible. But sometimes. The geometry creates some clashing. Then i starting adjusting some nodes into bigger one.
Here’s another approach which would work nicely with sheet metal connectors.
