Hexagon surfaces with independent horizontal segments
Hello everyone,
I’m trying to create some surfaces derived from a hexagon grid on a surface.
The extrusions of all horizontal segments would be differentiated (individually controlled/ series / ranged/ attractors).
The resulting dimensions of all diagonal segments are dependent on these horizontals.
I think I’m almost there except I’m having trouble connecting these diagonal segments highlighted in the attached image.
Any help is appreciated
Cheers
diagonalsurface001EXMT_Hex03.gh (17.1 KB)
EXMT_Hex03.3dm (165.2 KB)
found it a bit difficult to recreate the look. So if it’s important to you, that each horizontal line is extruded with one value, you can have a look at this. I also added the last bottom row. It got a bit messy, but I think I could solve your problem. This Definition could be simplified a lot.
EXMT_Hex_1.gh (21.0 KB)
If you want a smoother solution you can take a look at this. Just a simple attractor. You also can combine the two definitions.
EXMT_Hex_2.gh (10.2 KB)
I hope I could help you.
Hi Tim,
This works, thank you!
