Hexagon PolyLines C#
Hi all,
I try make a Hexagon Grid on a Surface in c#.Just like the Lunchbox component.
As base I used the scipts Nathan miller provided here: http://wiki.theprovingground.org/scripts-paneling
var p = new List<Polyline>();
double uStep = 1.0 / U;
double vStep = 1.0 / V;
t = t * uStep;
S.SetDomain(0, new Interval(0, 1));
S.SetDomain(1, new Interval(0, 1));
for (int i = 0; i < U; i++)
  for (int j = 0; j < V; j++)
    if (j == V - 1) // upper strip
      var pts = new List<Point3d>(7);
      pts.Add(S.PointAt(i * uStep, (j - t) * vStep));
      pts.Add(S.PointAt((i + 1 - 0.5) * uStep, (j + t) * vStep));//toMove
      pts.Add((S.PointAt((i + 1) * uStep, (j - t) * vStep)));
      pts.Add(S.PointAt((i + 1) * uStep, (j + 1 ) * vStep));
      pts.Add(S.PointAt((i + 1 - 0.5) * uStep, (j + 1 ) * vStep));//toMove
      pts.Add(S.PointAt(i * uStep, (j + 1) * vStep));
      p.Add(new Polyline(pts));
    if (j == 0)// lowest strip
      pts.Add(S.PointAt(i * uStep, (j ) * vStep));
      pts.Add(S.PointAt((i + 1 - 0.5) * uStep, (j ) * vStep));//toMove
      pts.Add((S.PointAt((i + 1) * uStep, (j ) * vStep)));
      pts.Add(S.PointAt((i + 1) * uStep, (j + 1 + t) * vStep));
      pts.Add(S.PointAt((i + 1 - 0.5) * uStep, (j + 1 - t) * vStep));//toMove
      pts.Add(S.PointAt(i * uStep, (j + 1 + t) * vStep));
    if (j % 2 == 0 && (j != V - 1) && (j != 0))
    // odd rows
    if (j % 2 == 1)
      if (i < U - 1 )
        pts.Add(S.PointAt((i + 0.5 ) * uStep, (j - t) * vStep));
        pts.Add(S.PointAt((i + 1) * uStep, (j + t) * vStep));
        pts.Add(S.PointAt((i + 1.5) * uStep, (j - t) * vStep));//moveDown
        pts.Add(S.PointAt((i + 1.5) * uStep, (j + 1 + t) * vStep));//moveUp
        pts.Add(S.PointAt((i + 1) * uStep, (j + 1 - t ) * vStep));
        pts.Add(S.PointAt((i + 0.5) * uStep, (j + 1 + t) * vStep));
      //left row
      if (i == 0)
        pts.Add(S.PointAt(i * uStep, (j + t) * vStep));
        pts.Add(S.PointAt((i + 0.5) * uStep, (j - t) * vStep));
        pts.Add(S.PointAt(i * uStep, (j + 1 - t) * vStep));
      //right row
      if (i == U - 1)
        pts.Add(S.PointAt((i + 1) * uStep, (j + 1 - t) * vStep));
Panels = p;
Its some kind of working but not really.
Maybe someone likes to help me puzzle, if not I would understand since its already a few lines, but as we say in my village: asking is free.
Regads!
HexGrid.gh (6.2 KB)
That’s a lot of code to look through for something that’s some kind of working but not really. Can you narrow it down to a specific loop or even line?
sorry for being so inprecise about that, when I read it again(some kind of working but not really) it actually made me laugh a bit.So thanks for answering even after that lazy description.
I will attach some pictures to explain myself this time( I hope).
So the actual state is that when the v divisions are a odd number it worlk fine:
Even numbers cause the following overlap in the highest raw.:
I wasnt able to figure out which line it causes, I think I might add a loop condition more to for the even cases.But I am not sure in total if I am on the rght way.
A minor issue should be put the correct t value so that it goes from triangle to hexagon to triangle in a range from 0 to 1. But also there I still failed.
So,thanks again,
if you are not interested anymoreI would completly understand.
Have a nice Weekend!
Hi Baris
I used to do this kind of work ,and I share you my file and screenshot, Hope that can help you
Hexagons from surface.gh (17.9 KB)
HI @tangchisg,
thanks for sharing!
You are using a different approch I think and changing mine to this would be a starting from zero basically.
I also found one Peter made with the same logic, but its way too advanced for me: http://www.grasshopper3d.com/forum/topics/hexagon-grid-deform?page=1&commentId=2985220%3AComment%3A1350619&x=1#2985220Comment1350619
I think a third approach would be do it completly by Pythagoras, but also that would be start by zero.
I ll keep trying…
Again thanks for sharing, its really nice done I think!
Regards!
