Hello. I do not know where to download supported version of heteroptera. Can you please share the gha?
Of course it would be even better if you can update your servers to the latest version of heteroptera
Here is the version currently supported on the ShapeDiver servers:
heteroptera_1.gha (1.1 MB)
Unfortunately, we cannot update the plugin to its latest version, as it does not follow backwards-compatible coding principles. Updating the plugin would put existing ShapeDiver models at risk to be broken because of the plugin changes. We will likely install the latest version directly to the Rhino 8 servers as they are not heavily used at the moment, and in the future new versions can be installed on private Shapediver servers, but not on the shared system.
thank you Mathieu!
