I am having an issue with the Import TOPO component and I would appreciate some guidance.
When I plug the same DEM GeoTIFF into Import TOPO, I consistently get:
@loc_tran Because that ImportTopo component is not showing the coordinate system message under it, I think it’s an old one from the Heron Example file. Try replacing it with a new one from the GIS Import | Export tab.
@loc_tran I’m using the same version as you: RH7 and Heron v.0.4.5 to test. It could be the characters with accents in the file path for the DEM file causing the problem. Can you try placing the DEM in a folder without them? If this is indeed the problem, I’ll look into fixing it in the next release, but note, I’ve started building for RH8+ only.
