Heron Slippy Raster Custom - imageFrame appearing in wrong location
I’m having an issue with Heron’s Slippy Raster Custom (SRC) component where downloaded map tiles appear in the wrong location relative to my boundary input.
Setup:
  • Rhino 8 SR21, Heron [0.5.1], Earth Anchor Point is set correctly
  • Creating a rectangular boundary in model coordinates around origin (0,0,0)
  • SRS Update component set to EPSG:4326, Toggle = True
  • Tiles download successfully but imageFrame output appears far from the boundary location
Strange behavior:
  • An older version of this same workflow works perfectly in the same Rhino file with the same EAP
  • The current version was working fine until last week
  • This happens at multiple project locations, not just one site
What I’ve tried:
  • Coordinate transformation (EPSG:32617 → EPSG:3857) before Slippy Raster
  • Different boundary geometry types (Rectangle vs Polyline)
  • Verified EAP is correctly set
Hi @felipezumaeta ,
Nothing has changed with Heron in the last couple months, since the release of v0.5.1. It works fine for me with the basic mapbox services.
Try the following:
  1. Verify your custom mapbox style is working properly.
  2. Assign a new prefix name
  3. Delete the cache of tiles in the folderPath location.
If you upload a sample file and definition, I could try troubleshooting in more detail.
-Brian
