Heron Plugin - Import LAZ - not retrieving points
I’m using the Heron plugin. Have added the node for “import LAZ”, connected the file filepath.
Panel shows zero points.
PLEASE NOTE, THE FORUM WOULD NOW ALLOW THE UPLOAD OF AN *.LAZ FORMAT FILE, SO I HAVE TEMPORARILY CHANGED THE EXTENSION TO *.X. JUST CHANGE BACK TO LAZ TO REVIEW
Points.x (642.5 KB)
Hi @Josh_Verran ,
Can you try saving the file out of CloudCompare as LAS or LAZ? I built ImportLAZ on laszip.net which can be picky about the source/formatting which created the LAZ.
-Brian
