I’m learning Rhino and am trying to install and run a script which the online author uses a lot in his material;
Pascal Golay’s “IntersectPlane”.
I’ve installed the script and when I try to use it, testing it out for the first time, I cannot seem to get it to work - I get an error which says;
“Source: Microsoft VBScript runtime error
Error: Type mismatch: “IntersectPlane”
Line:1
Char:0
Code:”
Please can someone advise ?
I’ve restarted Rhino - the script is there, I can type in the command, it just won’t work!
Rhino 5.0, Windows 10.
Many thanks for any assistance you can provide.
https://wiki.mcneel.com/people/pascalgolay
PS - I installed it by dragging and dropping the .rvb file into Rhino and restarting Rhino.
