I am trying to create a DataTable (to feed into DataSet and then Create json) and I am getting a red error message that I have been unable to debug. I can only assume there is something wrong with my input, but I am stumped as to what it is. It works in DataGrid just fine. All values are rounded to one decimal point, so floats shouldn’t be the issue? And I cannot read the whole error bubble, just “Solution exception: The input string ‘14.8’ was not in…”
What does the error message say? (click the raised box on the red component)
I can’t read the whole thing, clicking on the component does not expand the message. I can confirm other message bubbles expand just find in this file.
I just figured out it can handle integers fine, but it cant handle floats at all? They are rounded to one decimal but it can’t do it.
Click the part that you can read, the entire message should be copied to the clipboard?
Also attach a file so the community can help
