Hi
I was hoping to get some input on how I could better create the attached roof. The filled image is using loft between two curves created using grasshopper, however this only works smoothly in one direction, what i am hoping for are nurbs curves flowing in two directions so the bottom of each intersection is a rounded bowl. I’m sure there is a simple method I am missing. Was hoping for some help.
Hi Ash - can you post what you have? I’m not clear about where or if, you want hard corners - do you have an image of the desired shape? In any case, I think I’d do this by making one unit and arraying it, assuming they are all the same.
181211_3dRoof.3dm (193.9 KB)
Hi Pascal
The splines have been attached. No hard corners at all as per the attached image. Thanks
Ash.
