I have this 1/2" dia rod with a twist in the center - completely lost how to accomplish this same. Attached 2D.
Rod with Twist.pdf (142.6 KB)
I started with a extruded circle then possibly a helix but…really lost. Please help!
Twist command.
Okay!
It’s close, but I can’t get the subtle blend at the top and bottom of the twist…
Hello - please post what you have, I’ll take a look. It is not clear to me that this is a simple twist…
Hi Tamarah - the 2d drawing is a schematic, I would say, and not accurate, so you’ll have to interpret - for instance, unless the scallops are a series of ellipses and not a continuous twisted shape, you would not see the edges as straight lines in any view. Is the section of the twisted part square, for sure?
Also - if the goal is to mimic a twisted square rod, it will probably look more convincing (and not like the 2d) to set Infinite=No in Twist
so you get a suggestion of fall-off in the twist at the ends,.
Hi Tamarah,
Thinking about the physical object this represents, could you clarify whether it is a round bar with a machined helical pattern in the central section, or a representation of a forged (twisted) piece?
The former can be manufactured (caveats apply) but the latter is not possible - forging a twist in a round bar won’t produce defined scallops - that relies on the edges of the (typically square-sectioned) bar.
Regards
Jeremy
Understood! Thank you.
i SOLVED IT! It was honestly an easy answer, I am sorry for taking ya’ll time.
The rod is square…So the twist actually works.Twisted Rod.3dm (89.0 KB)
