Help with structure!
Hi!
I have these grid structures (green) which i need to meet in some way. I have two holes in the middle of the building (these are outdoor cutouts in the volume) which i would like the grid structure to meet. I also have these red lines which comes from the shape that i would also like to implement. Any suggestions is appreciated! in advance, thanks :slight_smile:
I have though about this (just without the column)
Are the grids all planar?
You could get a planar surface that includes all the grids plus the space in the middle and then use QuadRemesh. If the grids are fixed and cannot change then I think you can input fixed points into the QuadRemesher.
