Help with solving Trig problem
I want to script drawing the blue teardrop in the image below. Before going down my usual brute force and ignorance method of solving this I wonder if anyone’s got any bright ideas. What I want to do is pick the 2 red dots and be able to generate a tangential lead-in for a CNC toolpath.
I guess I can use CurveTangent to get to the centre of the arc then construct the rest from there.
Thanks Mark
Hi Mark
here is a quick demo script
import Rhino
import math
def main():
  ra = rs.GetReal( 'Radius ?' )
  cu = rs.GetObject( 'Curve ?' )
  p1 = rs.GetPoint( 'Point on curve ?' )
  p2 = rs.GetPoint( 'Other point ?' )
  uu = rs.CurveClosestPoint( cu, p1 )
  p1 = rs.EvaluateCurve( cu, uu )
  # 'vertical' axis: plane-with-curve normal or Z axis
  kk = rs.CurveNormal( cu )
  if not kk:
    kk = [ 0, 0, 1 ]
  ii = rs.CurveTangent( cu, uu )
  # curve normal
  jj = rs.VectorCrossProduct( ii, kk )
  jj = rs.VectorUnitize( jj )
  # possible center points
  c1 = rs.VectorAdd( p1, rs.VectorScale( jj, ra ) )
  c2 = rs.VectorSubtract( p1, rs.VectorScale( jj, ra ) )
  # pick the center point on the right side
  if rs.Distance( p2, c2 ) < rs.Distance( p2, c1 ):
    c1 = c2
  di = rs.Distance( p1, p2 )
  degs = math.degrees( math.asin( ra / di ) )
  vec = rs.VectorUnitize( rs.VectorCreate( c1, p2 ) )
  vec1 = rs.VectorRotate( vec, -90 - degs, kk )
  # joint point between line and arc ( 1 )
  t1 = rs.VectorAdd( c1, rs.VectorScale( vec1, ra ) )
  vec2 = rs.VectorRotate( vec, 90 + degs, kk )
  # joint point between line and arc ( 2 )
  t2 = rs.VectorAdd( c1, rs.VectorScale( vec2, ra ) )
  # aux point do draw the arc
  au = rs.VectorAdd( c1, rs.VectorScale( vec, ra ) )
  rs.AddLine( p2, t1 )
  rs.AddLine( p2, t2 )
  rs.AddLine( p2, c1 )
  rs.AddLine( p1, c1 )
  rs.AddArc3Pt( t1, t2, au )
  rs.AddTextDot( 'C1 X%.3fY%.3fZ%.3f' % ( c1.X, c1.Y, c1.Z ), c1 )
  rs.AddTextDot( 'T1 X%.3fY%.3fZ%.3f' % ( t1.X, t1.Y, t1.Z ), t1 )
  rs.AddTextDot( 'T2 X%.3fY%.3fZ%.3f' % ( t2.X, t2.Y, t2.Z ), t2 )
main()
HTH
Regards
Hi emilio
Thanks you for the example script, works great.:smiley: I’ll need to stare at it for a while so I can understand it well enough to put it to use in my project.
Thanks Mark
Yes, it’s a quick 'n dirty script …
If something looks confusing, just ask. :slight_smile:
