Help with Sloped Roof Trimming and Path Offsets
"Hi, I’m working on a masterplan project using Grasshopper. I need help streamlining my script logic.
What I’m doing:
  1. Islands: Subtracting road polygons from a site boundary to create building footprints.
  2. Offset: Creating a 100cm inward buffer using ‘Offset Intersection’ (to handle sharp triangular corners).
  3. Courtyards: Adding a central rectangular void (15% of area).
  4. Volumes: Extruding buildings to 27m outside, and trimming buildings inside to fit an existing Sawtooth Roof Brep.
The Problem:
My script is getting messy and I’m getting ‘self-intersection’ errors in sharp corners. I also need to ensure the final geometry is projected correctly to the model’s Z-elevation.
Looking for a clean, linear way to handle the Boolean Difference of the paths and the Brep Split with the sloped roof without crashing.
Thanks for any help!"
unnamed.gh (17.7 KB)
