Can anyone tell me how to model this Light fixture using just single span surfaces. I tries multiple time to model but somehow i do not get the right curvture in both direction. I tried to train myself first by lofting cross sections / create surface from edges but those were the results and do not think i am going in the right direction… I hope if anyone can help…
Hi Khaled - please post a file with what you have so far.
Sure… It is just full of alot of Trials
Hi Khaled - I think I would shoot for a surface patch layout along these lines - you’ll want to be more careful than I was about the consistency of that transition surface but something like this ought to work:
Thanks alot Pascal. I will try to do it as you have done and will update you
@Khaled_Ashraf1 - the tricky corner transition will work a lot better if the revolved surface is non -rational - make a version of the revolve that is 'Deformable=Yes" and use that to MatchSrf
your surfaces to, then trim them in to the actual rational (Deformable=No) revolved surface if you want, afterwards. MatchSrf
does not always do as well with exact revolved surfaces.
@pascal the surface is actualy not a revolved one as it is at the bottom more circular and as it moves up it become more rectangular. How can i turn it to deformable if it is not a revolved surface but lofted Surfaces?
-Regarding to your first comment about apply patch surface-- When i creat this inclined part by surface from edges it always generat polysurface not a single surface that i can not apply matchsurf on it. So to move on i tend to explode/unjoin them to get single surface. but then it gets complex.
-And sometimes when i matchsurf, it just work on one end of the surface and on the other not, it shows(not trimmed surface). Is there a reason for that and how to get over that and match the other end too?
Sorry alot of Questions but i am trying/training to get clean model with min Surfaces.
Definetely check out https://www.youtube.com/playlist?list=PLABJCJR46itOX8XT3bd2dh590McA94W7k if you haven’t already, by @sgreenawalt
Thanks alot @Gijs. I am already following him. He is the one who motivated to use just single span surfaces
Hi Khaled- please post the file in that state.
Hello
having fun yesterday I tried several approaches to find a solution with as few surfaces as possible.
I don’t know if this is good enough for what you want.
anyway, here it is.
luminaire.F .3dm (3.9 MB)
video is here
it just shows the main body modeling
I looked at your 3dm file that you shared.
I saw that you used degree 3 multi span curves to create your surfaces of revolution.
It’s not a bad approach. But it won’t give you single spans!
unless you reconstruct your surfaces. or you redivide them on the isocurves
Hallo Fares, Thanks alot man I appreciate your help. That is very nice from you.
I will try to do it again and update you…
Hi Khaled - given whart you have here - everything matching for tangency - I think I might go about this as in the attached file - if tnat seems like what you are shooting for, I’ll lay out some steps.
Light Fixture_T2_Maybe.3dm (354.9 KB)
I see Fares also has something for you - hopefully between the two of us you’ll get started.
In my opinion, @fares.boulamaali already showed the most appropriate way to create such kind of shapes. I would use the same technique, even though it’s a waste of time to do so, since a manually sculpted single multi-span surface with gazillion control points could do the job 100 times faster and easier, while maintaining perfect surface quality. Anyway, here is a step-by-step video tutorial showing the creation of a single-span model, in case that someone needs to waste over 40 minutes. I managed to do some minor mistakes during the video, so ignore those few moments.
Since Rhino is unable to properly loose offset single-span degree 5 surface and creates chaotic output surfaces, I used an old “hack” with using the hugely underappreciated “MoveUVN” tool to offset the control points instead. That results into almost flawless loose offset surfaces that need just a few touches to maintain their tangency along the border.
P.S.: The 4K/60 video is still being processed by YouTube, but should appear in a couple of hours.
Hi Bobi, I enjoyed your video. I could learn some things from you.
I was noticing something in your cursor movements as you worked. It was with the purge history. I saw you had to track all the way up to the command line to click All. That seems like a stretch from my point of view. It would be nice if it was on a right click for All. Just an observation. Thanks for sharing what you have done.—-Mark
thanks for the video.
To make the initial surface Degree 5x5 with 6x6 CVs.
Why do you use RebuildUV, 6 CVs, ChangeDegree, RemoveKnot.
instead of directly ChangeDegree to 5x5 ?
Hi Tom - RebuildUV
only makes degree 3… I guess Bobi is working around that. With six poiints it has internal knots.
