Help with lofting in the reverse direction
Im attaching the script down below
trumpet shaped column.gh (12.3 KB)
Any help would be appreciated!!
I’m not able to open up the script right now, but can you mirror the loft?
How do I obtain the plane, to mirror
Noob here, apologies
No need to apologize, we’re all learning - the inner curve is planar, so I got the plane it sits on, and then mirrored along that.
That being said, it may be simpler and will be more performant to make make one half of the column, mirror it, and then use a polar array to rotate them around the origin of the assembly, rather than making many of the exact same lofts at the same time.
Thanks for your valuable support!!
