Hello, I am trying to make an ETFE facade for a university project. this is my first ever time using rhino/grasshopper without any training. i could make the flat etfe facades, but i wanted to curve them to fit the form I’m working with. i tried my script with a curved surface and it didnt work, which i’m assuming is because of the 2d verouneill as well as the move componant. i attached my grasshopper script for the ETFE and the 3dm file (wetransfer cause of file size), as well as an image of what it looks like right now and the form I’d like to achieve. any help is very appreciated as I’m less than a beginner. Thank you!
Hi, @apala. Looks like you may have followed a flat surface Grasshopper tutorial, and now you are stuck attempting to apply that to a curved surface. I downloaded your file and took a look, however, your Rhino file didn’t download from WeTransfer. Rather than solve your problem directly (generally not the purpose of this forum), I’m going to point you to a few resources in the Rhino/Grasshopper ecosystem, that when you have time, will benefit your Grasshopper learning journey.
