Help with coving radius according to grid
Hi. Strugling a little bit with credenza door diamond pattern. I thought that it will be simplier.
Im thinking about way to create something similiar inside rhinoceros to catch proportions before i start with woodworking in real life.
Heres the thing i would like to archive
https://www.hambuiltcw.com/product-page/mid-century-modern-walnut-diamond-credenza
and heres the bit size i would like to use
https://pl.aliexpress.com/item/1005004581710471.html?pdp_npi=3%40dis%21USD%2118.08%2110.85%21%21%21%21%21%40211675cb16939235359967637e9753%2112000029708568555%21affd%21%21&dp=571325-124759.85532659&aff_fcid=da068893c1d445d08ef9dc9afe55f869-1693923536434-09224&aff_fsk&aff_platform=api-new-product-detail&sk&aff_trace_key=da068893c1d445d08ef9dc9afe55f869-1693923536434-09224&terminal_id=8499e35982d24d698df914abbddfd687&afSmartRedirect=y
my size is i think bith with radius 7.96mm, and depth of cut 7mm
I was trying to cut radius in half, array it couple of times, extrude and boolean on doors, but this technique sucks, perhaps you can point me out with something much more flexible ?
You know you can post screenshots by copy pasting?
nope i dont, I mean now i know thanks :slight_smile:
Ok, can you share your Rhino file?
sure. here it is. I would like to find method that will suit my needs so i could check different radius easly.
Probably my method is way to complicated.
credenza door.3dm (1.3 MB)
its extrude, array, mirror, boolean intersection involved → in short steps.
Testing 3dm Archive: C:\Users\martinsiegrist\Downloads\credenza door.3dm
Start Section: 463 bytes (offset 0 to 463)
Offset: 0
3dm archive version: 70
Interface Name: Rhinoceros 7.15 - Corporate, build 2022-02-08 - (compiled Feb 8 2022)
I do not support the use of cracked licenses. You’ll have to wait for someone else to help you.
I agree 100%
