Dear All,
Has anyone done any work in panel classification?
Something to classify through a set of surfaces (panels) and distinguish between flat, single, and double curve types?
Don´t know how to approach it, here is an image of what I need
Dear All,
Hey, do you have more information about your use-case?
What will the classification be used for?
Where do the paneled surfaces come from? do you have an example geometry?
This video is probably what you need:
Check this Definition:
DoubleSingleCurvaturePanels.gh (13.4 KB)
It uses Osculating Circles to determine if the surface is curved in one or two directions at a specific point.
Its not the cleanest Definition and I am sure there are more efficient ways but it seems to work in your use-case.
