I am playing now with Bowerbird plugin and have some questions:
How to make negative value of deeper connection. I have some problems with my small parts and I need to have shorter indent and i can make only longer.
I don’t think you can have a negative Deeper value. As you probably know, Deeper parameter is to account for the cutting tool radius.
I don’t think you can vary the slot width on specific slots either… If you pass a list of material thicknesses it generates a solution for every thickness.
Have you tried using the RSlits component in the Intersect tab?
