I can’t figure out what I’ve done wrong here…
I want o make an alias that will group a few curves and then hide them. Seems pretty simple.
Here is what I add:
grhd (Alias name) ! _Group _Hide
However, it doesn’t work. The _Group works but the _Hide doesn’t.
It seems to try to execute the previous command line command or something, providing ‘_Hide’ as an option. (As per the inserted image below…)
Here is the command history…
I’ve tried a bunch of different things in the alias but I can’t make sense of it.
thanks
Peter
Try this: ! _Group _Pause _SelLast _Hide
You need the _Pause to allow you to select the objects if they aren’t already preselected; the _Sellast is needed to re-select them after _Group because they get unselected (if they were not preselected).
! _Group _Hide does work if the objects are preselected, but ! _Group _Pause _SelLast _Hide works in both cases.
HTH, --Mitch
Hi Mitch,
I’m starting think it doesn’t have anything to do with the actual alias…
I tried your suggestion, but I had a similar problem, as follows:
As you can see, it just tried to repeat the previous rectangle commands… I can’t figure out why.
cheers
Peter
Odd… If you make a new alias (different one) does it do the same thing?
I just realized this is in the Mac category - since the alias stuff was recently revamped, maybe this is the problem? Check out this thread…
Hmmm,
seems that way. I tried a couple and same each time.
No problem with existing aliases.
is this just me?
cheers
Peter
PS, here is my machine info…
Software information
Software versions
Rhinoceros version: 5.0 Wenatchee 2014-06-10 (515)
OS X version: Version 10.9.3 (Build 13D65)
Plug-ins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
Hardware information
Computer hardware
Hardware model: MacBookPro10,1
Processor: Intel Core i7-3720QM CPU @ 2.60GHz
Memory: 16 GB
Architecture: Intel 64 bit
Video hardware
Graphics: NVIDIA GeForce GT 650M 1024 MB
Memory: 1024 MB
Screen size: 1600 x 1200, 1680 x 1050
Displays: SyncMaster, Color LCD
Third party kernel extensions
com.attotech.driver.ATTOiSCSI (3.4.1b1)
com.parallels.virtualsound (1.0.27 27)
com.nvidia.CUDA (1.1.0)
com.Logitech.Control Center.HID Driver (3.3.0)
com.3dconnexion.driver (1.7.1)
USB devices
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Inc.: Bluetooth USB Host Controller
Logitech: USB Receiver
Mitsumi Electric: Apple Extended USB Keyboard
Tablet: XD-0608-U
Bluetooth devices
None
OpenGL information
OpenGL software
OpenGL version: 2.1 NVIDIA-8.26.21 310.40.35f08
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
Appearance settings
Antialiasing: None
Mip map filtering: None
Anisotropic filtering: Low
As I edited my post above, the alias stuff on Mac has changed, see this thread…
