I’m new to rhino and have a metal fabrication shop. how can I add a density to a material to get the weight of it. example
I model a cube. I can drag aluminum to the solid. can rhino give me the weight?
getmassprops command says has no mass. I believe I need to add a density to the material???
another example would be to build a dinner plate. If I make the plate out of aluminum, it would have a weight
if I made it out of stainless steel it would have a different weight. how can I create a solid and give it a mass?
