Help with 3D print
Howdy.
I am still new to doing complicated stuff in Rhino.
I usually use it for simple vector work.
I am trying to modify an open source clamp design and print it on a Bambu PS1 FDM 3D printer.
The design is a complicated mesh and I ran MesthtoNurb to hopefully help me work with it.
I want to remove the 2 holes as shown in the attached jpg (where the yellow arrows are pointing to).
I want the piece to have fill where those holes were.
I am then going to add a flat area on the top of the clamp that is 1.635" wide and 2 screw holes.
Attached is the STL file for the clamp.
Mini - Frame.stl (626.1 KB)
How do I remove the 2 holes for starters?
THANKS SO MUCH.
You can achieve it with ExtractMeshPart + FillMeshHoles, and FYI.
amazing. Thanks so much
