Hi everyone,
I’m modelling a horse sculpture in Rhino that will be fabricated from 3 mm stainless steel sheets, cut, curved and welded together. Each surface represents a separate sheet.
At the moment, my surfaces have no thickness. The fabricator has asked me to account for the 3 mm thickness so the flat patterns have the correct dimensions after forming, especially because some pieces are strongly curved.
I’ve tried using OffsetSrf to add the thickness, but when I use UnrollSrf, I get the result shown in the attached screenshot, with separate faces and narrow strips rather than a single usable cutting pattern.
What is the correct workflow to account for the sheet thickness when developing these surfaces? Should I model the thickness, unroll a middle/neutral surface, or use another method?
I also have another issue: on most pieces, UnrollSrf reports that the area has increased by an amount ranging from 0.01% to 1.2%, depending on the surface. How should I interpret these differences? Could they cause significant problems with the cutting dimensions and fit between neighbouring pieces? What should I check to decide whether a development is usable?
I’m fairly new to this process, so a simple, step-by-step explanation would really help. This is urgent for us, and I would greatly appreciate any advice.
Thank you!
Título: Ayuda con escultura en inoxidable de 3 mm — espesor y diferencias de área con UnrollSrf
Hola a todos:
Estoy modelando en Rhino una escultura de un caballo que se fabricará con chapas de acero inoxidable de 3 mm, cortadas, curvadas y soldadas. Cada superficie representa una chapa independiente.
Actualmente, mis superficies no tienen espesor. El fabricante me ha pedido que tenga en cuenta los 3 mm para que los desarrollos tengan las medidas correctas después del curvado, especialmente porque algunas piezas tienen bastante curvatura.
He intentado añadir el espesor con OffsetSrf, pero al utilizar UnrollSrf obtengo el resultado de la captura adjunta: caras separadas y tiras estrechas, en lugar de un único desarrollo útil para el corte.
¿Cuál es el procedimiento correcto para tener en cuenta el espesor al desarrollar estas superficies? ¿Debo modelar el espesor, desplegar una superficie intermedia/neutra o utilizar otro método?
También tengo otro problema: en la mayoría de las piezas, UnrollSrf indica que el área ha aumentado en un porcentaje que va desde el 0,01 % hasta el 1,2 %, dependiendo de la superficie. ¿Cómo debo interpretar estas diferencias? ¿Pueden provocar problemas importantes en las medidas de corte y en el encaje entre piezas contiguas? ¿Qué debería comprobar para saber si el desarrollo sirve?
Tengo poca experiencia con este proceso, así que agradecería mucho una explicación sencilla, paso a paso. Nos urge resolverlo y cualquier ayuda sería muy bienvenida.
¡Muchas gracias!
