Hallo Guys,
i need help creating such an object the the twisted louvers skript above, the object must not necessarily be the same , but i want to design a room with walls as the twisted louvers.with the skripts i have used, one can only use a normal flat surface, but not a loft or more organic surfaces . It would really be helpful if some one would help me design it.Attached are the Skripts and the rhino model with a sample loft .Thanks
Please don’t double-post.
Original thread here: Help twisting louvers in Grasshopper using a curve attractor
