I have a sample 3D model in STL format, and I need to repeat it to create a 3D seamless pattern texture (a “rapport”).
These copies should form a panel with multiple repetitions, without any visible seam lines like a perfect, continuous pattern.
The texture must also maintain the surface roughness of the original sample. I would appreciate
I would appreciate guidance from fellow professionals on how to achieve this, perhaps using Grasshopper, Python, or any other suitable method.
Thank you.
I couldn’t attach the file any other way. Here is the link for the download:
I have requested access
Access granted!
The best way to do this is by converting the mesh to a displacement map (heightmap).
Then use image editor to make the tileable image. The image can be converted back to a mesh by applying the displacement map to a mesh.
