Hellow! Any way to use Sweep Rail in a profile and it auto-align without it being over the operation line?
Hi @igormp
Not automatically, but it’s easily done by using OrientCrvOnCrv. First select you profile, set a base point (eg. center) and then your rail curve. If you have you profile centered on 0,0,0 and lying flat on the top cplane, use the Perpendicular option in the command line to orient it perpendicular to the rail - see the help file for more.
HTH, Jakob
