Help show line when mouse move event
I want to show line to location of mouse, when mouse move line to redraw. I can’t do that. Please help me.
import Rhino
import scriptcontext as sc
def handle_mouse_move(object, e):
    try:
        ptS=[]
        t= e.WindowPoint.X, e.WindowPoint.Y
        ptS.append(t[0])
        ptS.append(t[1])
        ptS.append(0)
        ptS=rs.coerce3dpoint(ptS)
        print ptS
        #Show line begin 0 to location ptS
    except Exception as exp:
        print(exp)
def GetLoMouse():
    getter = Rhino.Input.Custom.GetPoint()
    getter.AcceptNothing(True)
    getter.PermitObjectSnap(False)
    getter.PermitOrthoSnap(False)
    getter.PermitConstraintOptions(False)
    getter.MouseMove += handle_mouse_move
    getter.Get(True, False)
if __name__ == '__main__':
    GetLoMouse()
Help me :frowning:
Read through this example: https://github.com/mcneel/rhino-developer-samples/blob/6/rhinopython/SampleCurveDirConduit.py
You can create a conduit just like this one, except you draw a line between the original point an the current mouse location.
Thank you! I’m try
Here are the methods you can call on the Display property:
https://developer.rhino3d.com/api/RhinoCommon/html/Methods_T_Rhino_Display_DisplayPipeline.htm
This support for C# and VB. I want show them in python rhino
import Rhino
    try:
        sc.doc.Views.Redraw()
        ptS=[]
        ptS.append(t[0])
        ptS.append(t[1])
        ptS.append(0)
        ptSS=rs.coerce3dpoint([0,0,0])
        color = Rhino.ApplicationSettings.AppearanceSettings.TrackingColor
        Rhino.Display.DisplayPipeline.DrawDirectionArrow(ptSS,ptS,color)
        print(exp)
def GetLoMouse():
    GetLoMouse()
Error: DrawDirectionArrow() takes exactly 4 arguments (3 given)
DrawDirectionArrow need 3 arguments , why 4?
Moved this to the scripting forum-
https://discourse.mcneel.com/c/scripting
You are supposed to use the Display argument from the event. That is line 30 from the conduit sample I linked:
the fourth argument is the implicit self that is given as the very first argument to the function when called as an instance method.
import Rhino
def handle_mouse_move(object,self,e):
    try:
        ptS=[]
        ptS.append(t[0])
        ptS.append(t[1])
        ptS.append(0)
        e.Display.DrawDirectionArrow(ptSS,ptS,color)
        print(exp)
def GetLoMouse():
    GetLoMouse()
script run but don’t draw line
That is because you don’t haven’t created a display conduit. Please revisit the sample I posted and observe the conduit class and how it is enabled and disabled.
You has use sc.doc.Views.Redraw() for show line.
I having use it but not show
import Rhino
    try:
        ptS.append(t[0])
        ptS.append(t[1])
        ptS.append(0)
        print(exp)
def GetLoMouse():
    GetLoMouse()
Hi @xiix.xoox, the easiest way without setting up a full conduit is just using RhinoScript syntax to pick a point and give the method a base point. The method then does setup a dynamic display conduit on the fly to draw the line:
import Rhino
def DoSomething():
    base_pt = Rhino.Geometry.Point3d.Origin
    test_pt = rs.GetPoint("Point", base_pt)
DoSomething()
If you want to draw other objects, eg. an arrow, you can do so by using a dynamic drawn conduit. Dynamic in this context means, objects drawn in the conduit are drawn without depth buffering and are always drawn in foreground. The benefit compared to regular conduits is that the dynamic conduit does not persist after the point picker is done, so you do not have to turn it off:
import Rhino
def DoSomething():
    color = Rhino.ApplicationSettings.AppearanceSettings.FeedbackColor
    def GetPointDynamicDrawFunc(sender, args):
        line = Rhino.Geometry.Line(base_pt, args.CurrentPoint)
        args.Display.DrawArrow(line, color)
    gp = Rhino.Input.Custom.GetPoint()
    gp.DynamicDraw += GetPointDynamicDrawFunc
    gp.Get()
    if gp.CommandResult() == Rhino.Commands.Result.Success:
        picked_pt = gp.Point()
DoSomething()
_
c.
