Help! rhinoscript error
hello,
since the rhino update, of this morning,
i ve got an error message when i launch a rhinosrcipt:
! _-Runscript (
Option Explicit
'Script written by <insert name>
'Script copyrighted by <insert company name>
'Script version mercredi 3 décembre 2014 15:01:55
Rhino 7 SR6 2021-5-7 (Rhino 7, 7.6.21127.19001, Git hash:master @ aec74c050f3ca28ab3cfd6882e9453a52366a9b7)
License type: Commerciale, version 2021-05-07
License details: Cloud Zoo
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 24Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro K4000 (NVidia) Memory: 3GB, Driver date: 12-6-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 441.66
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-6-2019
Driver Version: 26.21.14.4166
Z-Buffer depth: 24 bits
Total Video Memory: 3 GB
C:\Program Files\ADA 3D\Mesh2Surface for Rhino 6\m2s_for_Rhino.rhp “MESH2SURFACE”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoScriptEditor.rhp “RhinoScript Editor” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.6.21127.19001
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\SectionTools (fbdb1d7f-8cfb-42c1-9858-87cb6315932c)\2019.7.29.584\SectionTools.rhp “SectionTools”
one idea???
In Options>Plug-ins (Modules), check to see if the Rhinoscript plug-in is enabled?
(it is in the list in your SystemInfo, but I don’t know if that means it is enabled)
yes it is!!
Hmm, OK, and this happens with any Rhinoscript?
You could perhaps try a Repair installation - go to Windows control panel, Programs, Uninstall, find Rhino 7 in the list, right click on it and choose “Change” then on the splash screen, choose “Repair”
i’m on internet, but in the " fichier journal d’installation" it talk about DOWNLOAD CACHE FAILURE
do i have to re install all rhino 7?
This looks like it is a problem related to this -
and this -
https://discourse.mcneel.com/t/installation-problems/1238
Looks like the temporary solution is to download and install DotNet 4.8 first as per the directions in the last post in the first link above.
thank you, but no change, i do the solution in the discuss of the first link.
your second link doesn’t run…
i don’t know, what can i do… every rhinoscript run when i launch them form the editor, but, the command
! _-Runscript (
in the button doesn’t run!
all my rhinoscript in button, are write like this:
! _-Runscript (
[Script]
it was running… but now no, so i just add a ‘)’ at the end so:
! _-Runscript (
[Script]
and now it’s ok!!!
excuse me for time, it’s ok now i think!
Ah, I was under the impression that the last ‘)’ has always been required and that it would not work without that. So I assumed you had one in your button already.
