Help! Revit shutdown when using direct shapes
When i try to use direct shape geometry component in rhino.inside revit turn off and I cant save the file. What may be causing this problem? I am using rhino 7 and revit 2022.
Hi David,
Please go into the options and expand the details of the About info and either post a screenshot or paste the result. Thanks
Thanks, Lets get a bit more info and do some troubleshooting.
Please run SystemInfo in Rhino and post the result.
To quickly isolate Rhino & Revit from other revit addons we can start a new instance of Revit like so…
Hold Shift+Cntl and the Rhino Start Button on the Revit Ribbon (Green Dot)
To disable 3rd party plugins in Rhino you can go to the File>Properties> Plugins and sort by Plugins that do not ship with Rhino.
When i run without addins everything goes well. And i saw in rhino properties that d5 live sync was a plugin tat do not ship with Rhino. I assume that d5 plugin in revit is in conflict with d5 plugin in rhino. I will try to uninstall it.
I’ve reinstalled revit and rhino and the problem persists… after 10/15 minutes this appears and revit closes. I dont have any plugin in rhinothat do not ship with rhino…
Hello! I reset the computer and installed only revit and rhino, (rhino.inside also). After a couple minutes revit gives a message saying fatal error and i lose the progress made. So, the possibility of being a addin from revit or rhino causing trouble is excluded. I have installed other revit versions and a rhino 8 version and the problem persists… I tried with rhino 8,7, revit 2022 and 2024.
Hi David,
Not able to replicate here as of yet.
A minor different version of Revit, also on the latest Daily build. I rolled back to yours with no difference. I’m only a PyRevit in Revit Addins & Elefront in gh.
Lets get as much info as possible.
Please run SystemInfo in the Rhino command line and post the results.
What is your current Rhino.Inside.Revit build you are installing?
Are all the Revits been updated to the latest?
Thanks
Everything has been updated to last… Inclusive the new revit update hotfix… I would like to try to install an older version of rhino inside. How can i do that? I tried the last daily build of rhino inside but the fatal errors keep appearing.
Rhino 8 SR9 2024-7-12 (Rhino 8, 8.9.24194.18121, Git hash:master @ 785b9fde79bb684d22aab317998f7195a8c27c14)
License type: Educational Lab License, build 2024-07-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [98% battery remaining]
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 10-3-2022 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-10-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.70
> Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-10-2024
Driver Version: 32.0.15.6070
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\david\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\D5Conv.rhp “D5 Live Sync for Rhino”
C:\Users\david\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Karamba3D\3.1.40718\Karamba3D_LicensePlugin_Rhino8.rhp “Karamba3DLicense”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.9.24194.18121
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.9.24194.18121
Still leaning towards a plugin conflict. I saw that you requested an older version of RiR, which i am sending you via DM.
directshape_import.gh (8.4 KB)
U also have problems when using this ?
Good morning! I tried to use the older version and everything works fine when using rhino 7 and revit 2022. I didnt erase or disable any plugin and works perfectly fine. When i tried to use rhino 8 and adjust the dimension of the layers tab all the tabs of rhino went crazy. But thats a thing that already happened in the past, I have been using rhino 7 because of that. With 8 i have to be reseting the tabs all the time. Thankyou very much for your help with this older version i can work. I hope these problems could be solved in further updates of rhino inside.
