I am having trouble adding a list of items into an existing data set. The items want to be added to a new branch which will be a new last branch in the data set. The only way I can think to do this and keep it parametric is to take the path count, add one, construct it into a path and then add the items to this path and merging the data together.
The best solution I have right now is to use path mapper and manually change the number I need but this makes it none parametric which is not what I’m after.
If anyone has any suggestions on this I would be eternally graefull!
Renumbering paths.gh (43.7 KB)
